cooling system visual test
Old Mar 4, 2002 | 11:56 PM
zimmer's Avatar
What are the signs off a bad thermostat or bad waterpump? Before I started my car this morning, I took the radiator cap off and start my car. The coolant inside was moving around. I read earlier that the coolant shouldnt move at all. MY car does run up to 240 on the freeway and I know I dont have a front air dam. I would like to completly replace everything that doest work tomorrow(day off). Any tips welcomed '88 GTA 350
Old Mar 5, 2002 | 12:30 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
See your other post I referred to. As far as the coolant. It shouldn't be moving around when you first start your car, that means the stat is open. The stock stat is I believe 195*, so coolant shouldn't circulate until then, but if it's moving freely your pump is fine.
Street Lethal
Apr 30, 2019 12:14 PM
mddaniel
Sep 8, 2015 05:16 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
TheExaminer
Aug 26, 2015 04:59 PM
sreZ28
Aug 14, 2015 07:48 PM
