Overheating!!!!!!!!!!!!!
Old Mar 6, 2002 | 08:08 AM
NOCANDO's Avatar
Ever since I installed my headers, open element filter, and flowmaster cat back exhaust, my 92 camaro over heats!!!! The only way the temperature goes down is when I turn on the AC with the fan on. I replaced my air dam, but with the same problem. I even changed to a thicker oil, but to no avail. With all the new bolt ons, could it be my timing????
Old Mar 6, 2002 | 08:19 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
If turning the AC on cools your car, that shouldn't happen usually AC will warm a car up. I would check to make sure your fans are coming on properly.
Old Mar 6, 2002 | 08:23 AM
Buck268's Avatar
same with me. I will be putting a lower temp FAN SWITCH in when I swap my 'new' used LT1 cam in...
Old Mar 6, 2002 | 09:07 AM
1986redbird's Avatar
check to make sure you didn't knock the fan switch connection off when you were installing the headers, the fan switch is located on the passenger side head between #6 and #8 spark plugs.
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
mustangman65_79
Sep 1, 2015 03:51 PM
JHX
Aug 29, 2015 02:30 PM
jbd1969
Aug 17, 2015 07:06 PM
