Rockers???
Old Mar 8, 2002 | 09:37 AM
5.7lformula's Avatar
Rockers???
Can somebpdy please help me and tell me what kind of rockers i need? I have a 92 Formula. 350 TPI. Im swaping to a ZZ4 Cam and have to get new srpings might as well get rockers. I have browsed around and find some but dont know what specs i need and what will be benifical. I was told to get 1.6. But theres also the choice of different stud sizes adn what not. Can somebody PLEASE help me.
And does anybody know where to get a set of ZZ4 springs?
Thanks Jesse
Old Mar 8, 2002 | 11:23 AM
Vader's Avatar
Formula,
Your engine was originally equipped with 1.5:1 stamped steel rocker arms made to fir 3/8" studs. These rockers are a self-aligning design, with a shallow groove in the valve tip end to keep the rocker centered over the valve.
Any replacement shouldbe suitable. If you change teh rocker studs to a different size, you will of course have to get a different size rocker. You can choose to install 1.6:1 rockers if you desire, as long as the valve springs will tolerate the additional lift. And any replacement should be of the self-aligning design unless you have removed the studs and machined the heads for push rod guide plates.
With that cam profile, you should replace the studs, and need to replace the springs. The replacement studs should be of the screw-in variety instead of the factory pressed-in studs (which will be "pull-out" studs if you don't replace them). You can do this replacement yourself or pay a machinist to do it, as long as you remove the heads and take them to their shop.
For correct springs, check the supplier of the camshaft, or www.sdp2000.com
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
New2Chevy
Sep 28, 2015 12:35 AM
Billyadams
Sep 22, 2015 08:25 AM
ericjon262
Sep 11, 2015 06:07 PM
