V6 Mass Air Flow Sensor
Old Mar 9, 2002 | 09:16 PM
Ratchet's Avatar
How do I check the Mass Air flow sensor on my V6
I can find all kinds of posts for checking mass air flow on V8 engines which must have a bit different set up because virtually all of the posts tell you to check the voltage at the green wire should be .5 at idle and 5 at WOT etc. etc. etc.
There is no green wire on my V6
I found a reference to checking the voltage at terminal C on the MAF plug in a book I have but it does not tell you which terminal is C again
Please help
eightsixseven
Dec 16, 2024 01:50 PM
chazman
Aug 28, 2018 03:25 PM
Keith5
Aug 27, 2015 04:37 PM
chazman
Aug 22, 2015 02:01 PM
