Error Codes?
Old Mar 10, 2002 | 03:13 PM
TrnsmGTA's Avatar
Car: 87 Trans Am
Error Codes?
Been having alot of problems with the engine feeling like there is a vaccum leak. Replace all the emissions hoses, valves, spark plugs & wires, fuel filter, oil change, O2 sensor and today replaced the MAF sensor because i got Code no. 34. I also got codes 42 & 44, but just replaced the O2 sensor. Anyone have any suggestions...been trying to work on this problem the last month and no progress.
Old Mar 10, 2002 | 07:54 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
Re: Error Codes?
check your fuel pressure. 44 means lean exhaust. fuel pump could be on the way out. or something as simple as the relay not working correctly.
Old Mar 10, 2002 | 09:37 PM
TrnsmGTA's Avatar
Car: 87 Trans Am
Chugging
How do i check the fuel pump pressure or tell if the pump is bad. I don't think it's been replaced since i've had the car, but at high speeds the car runs great, it's only at slow speeds when i give it a little gas and it really jumps and chuggs until i give it alot of gas and then it runs. Any suggestions? Fuel injectors have been cleaned too and i see no vaccum leaks?
Old Mar 10, 2002 | 10:01 PM
mrr23's Avatar
Engine: 360 HSR
Re: Chugging
if it's a tpi motor, then the test port is on the passenger side fuel rail in the rear. if it is tbi, then you'll need an adapter to install at the fuel filter to test it.
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
3rdgenparts
Sep 28, 2015 10:47 PM
mfp189
Sep 27, 2015 09:25 AM
