Best fuel injectors and runners to use on '90 iroc?
Old Mar 10, 2002 | 05:52 PM
jd13's Avatar
What would be the best fuel injectors and runners to use on a 1990 iroc z Camaro (5.7, 350)
Any links or suggestions would be helpful, thanks.
Old Mar 10, 2002 | 09:14 PM
89Irocz23's Avatar
im not sure about fuel injectors but for the runners I would suggest putting the SLP ones on there. There not a bad price and u'll notice u'll have more power in the higher rpms. Also to add to that note I would port your base and your plenium to see the whole benefit.
Old Mar 10, 2002 | 10:41 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
it depends on what your plans for the car are. if your going for mild mods i'd say edelbrock runners and base if you can afford it, otherwise for higher rpm i'd say go with SLP runners and port to match. as for injectors i'd say go with accel.
Frozer!!!
Jan 19, 2024 04:55 PM
bryan623
Mar 22, 2021 06:43 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
mustangman65_79
Aug 11, 2015 03:17 PM
