where is the starter enable relay?Neutral safety switch?
Old Mar 11, 2002 | 12:05 PM
89chevy350's Avatar
i am having a problem with my car. when i turn the key i am not getting anything. Starter wont turn or nothing. The battery does turn on thats it. Its not the starter because we gave it some juice and it worked so we are thinking maybe its the ignition. If you might have an idea of what the problem is please give me a hand. I need to know where the starter relay is and the neutral safety switch is on the car. Thanks for your help Matt
Old Mar 11, 2002 | 04:40 PM
AFRO IROC Z's Avatar
When you turn the key to the on position do you hear the fuel pump turn on. I don't know if you are having the same problem i had, but one day i messed with my car and when i went to start it and nothing. But my head lights worked my radio worked and stuff but wouldn't start. Well after 2 days of searching I found a little fuse that is the fuel pump/ecm fuse. Mine was located right above the battery but you can't see it because it is inside a little black capsule it was attached to passenger side fender. I have an 87 iroc with tpi. Well i hope this helps. I know the feeling all to well
Old Mar 11, 2002 | 05:56 PM
jichniow's Avatar
Car: 89 IROC-Z
Engine: 6.0L LQ4
Transmission: 4l60e
Axle/Gears: 3.70
The Park/Neutral saftey switch is located at the base of the shifter. You'll have to remove the ashtray/shifter plate to get to it. It's not too hard to replace and I think it's only about $20.
Old Mar 11, 2002 | 05:58 PM
ihateallmustangs's Avatar
or u can bypass the neutral safety switch like i did and forget about your problem.
Old Mar 12, 2002 | 12:37 PM
nova65ss's Avatar
park neutral switch
How did you go about disabling the p/n switch? do they check when you take your car to the track if it is working? Never had it at the track so I was just wondering. Didn't want to do away with it if they did. thanks
Old Mar 12, 2002 | 01:26 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Yeah, how did u do that?? Sounds like u might need to readjust it maybe 89.
Old Mar 12, 2002 | 05:06 PM
to bypass the neutral safety switch..
#1. remove the shifter plate/ashtry.
#2. on the right hand side under the shifter plate u will see to big wires [purple and green in my car] that are part of the safety switch wiring harness.
#3. take the two big wires, cut them off at the plug then splice them together.
your done.
no more trouble with the fkin thing. and they dont check at the track where i go beacause its to much of a pain to have people takin apart their console's.
Old Mar 12, 2002 | 05:24 PM
89chevy350's Avatar
whats the point of bypassing the neutral safety switch?
Old Mar 12, 2002 | 06:50 PM
Omar's Avatar
You bypass it in case you dont like your current garage door.
Old Mar 12, 2002 | 06:55 PM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
It's one of the first things checked at our local track. Put in it gear, if it starts, it fails. They do give you two weeks to fix it but you don't get your sticker until it's fixed.
It should only be done to diagnose a problem!
Old Mar 12, 2002 | 07:15 PM
Hulk0202's Avatar
What year is your car? Do you have VATS? If the chip on your key is damaged, it will turn everything on, but when you try to crank it....nothing.
Old Mar 13, 2002 | 09:35 PM
89chevy350's Avatar
my car in an 89 camaro.What is VATS?.What do you mean chip on my key?
Old Mar 13, 2002 | 09:41 PM
Hulk0202's Avatar
That means you probably dont have it, but my 91 has a vehicle anti theft system. Theres a small chip(its actually a resistor) on the key that the computer reads. If it doesnt receive the correct signal it wont start.
Old Mar 14, 2002 | 08:04 AM
Vader's Avatar
There is also a start enable relay in the left kick panel area.
And wouldn't it be easier to repair the problem than to rewire the car? Just sayin'...
Old Mar 14, 2002 | 04:15 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
and if you were to bypass it i would use crimp connectors at the minimum, instead of simply twisting them together, unless you wish to have them work apart and have same problem again and have to take console back apart again
from this thread i have learned two things about the cars: red and green wires, and in the console and a relay maybe in the left kick panel, yay
good luck
Street Lethal
Apr 30, 2019 12:14 PM
Caspar
Jun 19, 2016 11:19 PM
my86bird
Oct 23, 2015 12:20 PM
Slush92RS
Sep 2, 2015 08:56 PM
5spdcamaro
Aug 28, 2015 02:12 AM
