need help please
Old Mar 11, 2002 | 10:14 PM
camarochic's Avatar
Car: 86 Camaro Iroc-z, 86 Corvette
Engine: 350 TPI Camaro, 350 tpi Corvette
need help please
Hey I need help now desperately when I try to start my car I don’t here the fuel pump buzz. I checked the fuel pressure and it is zero. When I tried to apply power directly to G of the aldl I heard a relay clicking but still no fuel pressure. I just had the fuel pump changed. I am stuck at work and I need to go home. Please some one help me
Desperately, Camarochic
P.S My car is a 1986 camaro, TPI, 305, Iroc-z
Old Mar 11, 2002 | 10:20 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
Well the relay could be bad. Did you check the fuse for the fuel pump? I think there is one. I would try wacking the relay and see if you hear anything. its on the drivers side under the hood.
Old Mar 11, 2002 | 10:21 PM
rezinn's Avatar
Check the connector above the differential for power when the key is turned?
Old Mar 11, 2002 | 10:32 PM
camarochic's Avatar
what wire is what?
Old Mar 11, 2002 | 10:41 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
sorry to ask this but can you send me sometime what you had to do to get that 91-92 dash in there? On teh drivers side of the gas tank there is a connector that is the power to the fuel pump and the other is the sending wire for the gauge. One of those will have power.
