some one has to know
Old Mar 11, 2002 | 10:23 PM
camarochic's Avatar
Car: 86 Camaro Iroc-z, 86 Corvette
Engine: 350 TPI Camaro, 350 tpi Corvette
Hey I need help now desperately when I try to start my car I don’t here the fuel pump buzz. I checked the fuel pressure and it is zero. When I tried to apply power directly to G of the aldl I heard a relay clicking but still no fuel pressure. I just had the fuel pump changed. I am stuck at work and I need to go home. Please some one help me
Desperately, Camarochic
P.S My car is a 1986 camaro, TPI, 305, Iroc-z
Old Mar 11, 2002 | 10:33 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
it's not a matter of not knowing, it's a matter of not being able to fix it from here.
Old Mar 11, 2002 | 11:55 PM
Guest
Guest
Posts: n/a
The relay is under the hood by the brake booster, you might want to make sure the wires are all connected, they like to melt the insulation and expose the wires. Should be the one closest to the front of the car of the 3 relays mounted to the firewall. You could also try giving the gas tank a smack with something like a piece of wood, not enough to dent it but enough to ring its bell. This will sometimes jar a bad pump or loose connection enough to get it to work, but trust me it usually wont last long in that case (like 1/8 mile is what I have seen... twice.)
Old Mar 12, 2002 | 11:11 AM
rocc4u's Avatar
Car: 1992 Z28
Engine: 383 Miniram
There is also a in line fuse in a single wire up by the battery. I spent a couple moons replacing the fuel pump, filter and relay. Turned out it was that damn little fuse. Hope this helps..
Old Mar 12, 2002 | 04:13 PM
AFRO IROC Z's Avatar
rocco-That's funny i spent about two days chasing that same little fuse, only thing is i knew it was there somewhere when i looked at the wiring diagram but couldn't find it because it was it the capsule. I would check that fuse also, can't hurt and good luck, i know what it is like to have a no start
