head bolt torque question
Old Mar 19, 2002 | 09:59 AM
johns84bird's Avatar
Car: Pontiac Grand Prix GTP
Engine: 3.8L V6 SuperCharged
Hey guys,
I put my heads back on a few days ago with Permatex Thread Sealant w/ Teflon (14) to seal them after reading several posts about how to seal them. Now, I torqued them down in the proper sequence first at 50, then 55, then 60 ft-lbs. The sealant says they may be tightened up to 24 hours after installing without breaking the seal. Well I just read they should be at 65 ft-lbs.
Do I need to take them all out, re-seal and retorque them, Or do you think it'll be fine with only 5 ft-lbs less than spec???
Thanks,
John
Old Mar 19, 2002 | 10:31 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
if your using an aluminum head.. your going to be close
Some of the AL heads are 70ft/lbs.. But, i would not try to go the extra 5. The sealer will set a little and you will mess that up.
Old Mar 19, 2002 | 10:46 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There is more danger of failure from over-torquing than from slightly under-torquing them. I usually only use 60 ft-lbs anyway because the castings start to distort above that, which ends up creating leaks between the center 2 cylinders. And, that particular thread sealer makes a really good lubricant (thereby lowering torque readings at any given clamping force), so you should probably leave the torque a bit on the low side anyway.
My advice would be to leave them alone.
Old Mar 19, 2002 | 12:42 PM
awesome, guys! Thanks for the advice.
John
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
355tpipickup
Aug 25, 2015 12:54 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
