Figuring Compression..Help
Old Mar 26, 2002 | 07:21 PM
Kwik88's Avatar
Car: 1988 IROC
Engine: 383 SP
Axle/Gears: Dana S60 4:10
I'm trying to figure compression on a '88 350. Does anyone know what the stock head gasket thickness is and what the piston dish cc's are for the L98? Thanks
Gary
Old Mar 27, 2002 | 09:47 AM
Vader's Avatar
Kwik,
IIRC, the OEM head gaskets on L98s should be 0.031" compressed. Pistons should be flat-topped with about 6cc worth of valve reliefs. If you have Corel QuattroPro or MS Excel, you can download this file and retrive many common engine specifications, and calculate compression, volumes, etc.
Engine Calculator
sheachopper
Jul 31, 2019 11:27 AM
RedLeader289
May 28, 2019 01:47 PM
mrbird
Oct 20, 2015 03:43 AM
aaron7
Sep 30, 2015 09:15 AM
Zell1luk
Sep 29, 2015 10:36 AM
