will the egr work with vortec heads?
Old Mar 27, 2002 | 04:12 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
i have a set of heads and want to get them milled for my 305 but i was woundering if the egr will work with the heads, and is the a vortec intake that accepts the egr valve thanks in advance.. Kevin
Old Mar 27, 2002 | 05:02 PM
wiggy'sIROC's Avatar
Car: 1986 IROC
Engine: 305 going to 355
From what I have read, the Vortec heads have no EGR provisions, and I am sure if the heads don't, then the intake manifold won't.
Mark
Old Mar 27, 2002 | 05:04 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
ok that is what i thought... do the aluminum l98 heads.. I dont think they do either...I really dont know what heads to get for a 305... the world ones dont seem to preform as well and cost alot more... Kevin
Old Mar 27, 2002 | 10:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There is one carb Vortec manifold with EGR mount provision. You have to plumb exhaust up to the intake via an external tube. Same for aluminum L98 heads (that's what they did on Vette TPI's). The SD base includes the external EGR tube boss.
Think about what you're saying about Vortec vs. Worlds.
With Vortecs:
- Special intake manifold/base required
- Above-mentioned external EGR tube required
- Press-in rocker studs
- Really, really poor valve springs
- Factory production-quality castings
- Milling required for use on a 305
With Worlds:
- "Regular" intake manifolds fit
- Cross-over passages so internal manifold EGR works
- Screw-in rocker studs
- Good valve springs standard, upgrade springs cheap
- Aftermarket performance-quality castings
- Version available for 305
You didn't say which World heads you were using for comparison, I'll assume S/R Torquer 305's. World admits their heads benefit from bowl work, but even a first-timer like me didn't have any trouble doing that. The money you won't spend on a special intake manifold, machining for screw-in studs, and decent valve springs will more than pay for the Worlds. With a little die-grinder work, they will out-flow Vortecs.
Old Mar 28, 2002 | 12:12 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
ok thanks
Hey thanks for the breakdown 57kid.... Yea i was thinkin about the sr 305 heads... I will prolly just get those since they have better springs to begin with... sr heads with a bowl port job,perfomer intake,comp cams 256 cam with slp 1/5/8 headers, i already have a flowmaster cat back, its gonna put on a l69 engine
Thanks again Kevin
Old Mar 28, 2002 | 12:32 PM
BitchinCamaro's Avatar
Just a note, I got my vortec heads new, machined for screw in studs and guide plates, new valves & valve job, and springs good to .550 lift for $500. So its not that big of an added cost, you just need to shop around.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
