rocker stud torque using gm studs?
Old Mar 30, 2002 | 03:03 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
i have modded vortec heads for .550 lift and need to know the correct torque rating to install the rocker arm studs to?
and they already have the sealant on them....
thanks
Old Mar 31, 2002 | 12:49 AM
3.8TransAM's Avatar
TTT
I really need to know and im not having luck searching for it
thanks
Old Mar 31, 2002 | 09:08 AM
Vader's Avatar
3.8,
Into cast iron or steel, the following should apply:
Aluminum is a different set of specs entirely.
Apply some fresh threadlocker to your 7/16-14 stud bases and torque to 30-35 ft/lb in iron heads.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
