Tune up!
Old Mar 31, 2002 | 12:59 AM
Greg Kuhlmann's Avatar
Tune up!
when i got the car it had 120.000 miles on it. now its bearing down on 130... i changed the pcv valve spark plusgs airfilter cleaned the carb... but im thinking of doing another one this week.
wires, plugs, air filter, feul filter, pcv valve... besiedes engine oil what else goes in a tune up that you can think of... a normal one atleast.
Old Mar 31, 2002 | 01:03 AM
WaynesRS's Avatar
Don't miss the cap and rotor !
Old Mar 31, 2002 | 01:04 AM
WaynesRS's Avatar
and oxygen sensor
Old Mar 31, 2002 | 01:38 AM
ChevyLuva3's Avatar
tranny fluid... volts/ohm/amps check of sensors and such, wanna make sure everything is running electricly correct, atleast I do.
Old Mar 31, 2002 | 01:48 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Tranny fluid change and filter.
Old Mar 31, 2002 | 02:18 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
yeah what they said
Old Mar 31, 2002 | 09:38 AM
Vader's Avatar
Greg,
In addition to adjusting the timing, high idle cam, choke pull-off, curb idle, checking the TPS on your carb, adjusting the mixture control solenoid, you should stick to the factory service schedule:
Old Mar 31, 2002 | 06:12 PM
WaynesRS's Avatar
Hey Vader , thats pretty neat , where did ya get that ?
Old Mar 31, 2002 | 08:21 PM
Vader's Avatar
It's in my archives. It is a compilation of GM-recommended service intervals for '88-'92 vehicles, but applies to most newer ones too.
Old Mar 31, 2002 | 08:32 PM
WaynesRS's Avatar
Thanx for posting !
Old Mar 31, 2002 | 09:22 PM
ChevyLuva3's Avatar
Hey Vader how bout the timing chain, when should that be checked?.. replaced?
Old Mar 31, 2002 | 09:42 PM
Car: 99 Formula
Axle/Gears: 342
I think around 150k, but if you ever do a rebuild or cam swap when the car is approaching 100k, I would go ahead and change it then, they're not that expensive for the amount of work that needs to be done.
Zell1luk
Sep 29, 2015 10:36 AM
