NEED HELP ASAP w/ TPI wiring harness (swapping from TBI to TPI)
Old Apr 1, 2002 | 04:44 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Transmission: rebuilt 700R4
Here's my problem...i need help quick. I'm in the middle of swapping out my 89 tbi setup for an 88 TPI setup. When we layed the 2 wiring harnesses side by side, we noticed that the TPI harness has a fuel pump relay and fuel pump boss primer plug (that's what it's called in the haynes manual), and the TBI setup didnt. This means that the plug on the TPI harness has nowhere to plug into. So how is the fuel pump going to come on? I'm thinking that maybe the plug is something that can be bypassed, or i'm going to have to splice the wires off that plug into the wires leading to the fuel pump. What I dont get though is...how did the TBI pump turn on if it didn't have a fuel pump relay?? It had to have some other method. If anyone knows anything, help me out...thanks
Old Apr 1, 2002 | 06:29 PM
Tonyrodz's Avatar
Transmission: auto
I don't have an answer to your question--but you have to swap out the tbi pump for a tpi fuel pump. The tbi pump doesn't push enough pressure--so it won't run(once the tpi is all in).
Old Apr 1, 2002 | 08:50 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Yea, I know...the pump goes in tomorrow. I'm dreading it though, because I hear you have to drop the exaust, take off the springs, etc. But thanks for the heads up anyways.
Old Apr 1, 2002 | 08:51 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
I've read that the fuel pump is actually activated by the Oil pressure switch....if that's so, then Its not absolutely necessary to have the fuel pump relay hooked up....it'll just take longer to crank right?
BlueIroc-Z
Jun 9, 2019 03:22 AM
9192camaro
16
Feb 3, 2019 12:21 AM
dutch930
Sep 11, 2015 06:58 AM
wickedfbody
Feb 7, 2001 08:03 PM
90FFBird
Nov 17, 2000 06:12 PM
