Dyno Program
Old Apr 3, 2002 | 12:40 PM
fordsuks91's Avatar
Car: 89 Formula
Dyno Program
I was just wondering if anyone had a dyno program and if they could run my motor on it. All my specs for my 383 are below. I will be running a dual plane intake if that helps, probably a stealth or a holley. Thanks, Danny
Old Apr 3, 2002 | 01:14 PM
rhuarc30's Avatar
To get an accurate run we need more specs than that. We need the airflow on those heads, duration and intake centerline on that cam. And i'd check the comp ratio math again. If your running a domed piston on a 383 you'd need a pretty good sized combustion chamber volume to get it down to 10:1. if you run a 64 cc chamber your more likely to be around 11.5:1.
Old Apr 3, 2002 | 02:19 PM
Stroked-Z's Avatar
Tell me about it!!!!!!!!
Old Apr 3, 2002 | 02:41 PM
fordsuks91's Avatar
Car: 89 Formula
Im running a 76 cc head. The guy at summit says that ill be running at 10.1.
djmarch
May 8, 2016 11:32 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
LT1Formula
Oct 8, 2015 08:34 PM
ULTM8Z
Oct 2, 2015 01:25 PM
