Sparkplugs with vortec heads and TPI
Old Apr 3, 2002 | 11:45 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Should i stay with stock heat range ? or should i step the heat range down anothc or two?
looking for some opinions
later
jeremy
Old Apr 4, 2002 | 01:14 AM
Guest
Guest
Posts: n/a
Theres no reason you should need anything other than stock. I'd run stock heat range, check them after a few hundred miles and see if they look right, then change them to a different range if needed.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
