Compression Increase?
Old Apr 4, 2002 | 09:30 PM
Buck268's Avatar
Would the compression increase if a cylinder was bored from 3.875 to 3.937 inches? this is not third gen related, sorry, but a friend is building his 250 straight six up from his 78 camaro LT, and got a bit confused (as did I). thank you!
Old Apr 4, 2002 | 10:09 PM
Guest
Guest
Posts: n/a
If all else remains the same, yes it will but not significantly IMO. Probably about .2 if all else remains the same cc-wise.
Old Apr 4, 2002 | 10:12 PM
Buck268's Avatar
OK, thats what I was wondering. He will be putting a 292 crank in (4.125" stroke, I think), so thats gonna raise compression, even with shorter rods.
Old Apr 4, 2002 | 10:19 PM
Mug-'s Avatar
Yes, that only yelds a 0.28 change in compression ratio.
Old Apr 4, 2002 | 10:26 PM
Guest
Guest
Posts: n/a
Building up an inline 6, thats different. I'd like to hear how that runs.
Old Apr 4, 2002 | 10:31 PM
Buck268's Avatar
As would I! I'll try to get sound clips of it when he's done. He's starting out with a really trashed 250 (I mean, when he pulled the head off, he found a little plastic ring, similar to those around the cap of a oil bottle, in the chamber). He is throwing a 292 crank in there, and it was bored out .062" totalling 306.5 CID!! Thats insane! If that was an 8, man, he'd be looking at 408 CID with that bore and stroke...crazy engine he's gonna have...
FormulasOnly
Jul 23, 2018 08:47 AM
gord327
Oct 3, 2015 01:25 PM
hartsmike
Oct 2, 2015 07:11 AM
WhteRbt
Sep 21, 2015 09:48 AM
