Valve guides should i replace them??
Old Apr 8, 2002 | 12:49 PM
howsci's Avatar
I've got some a stock 305 i am going to port and polish my heads in the near future. i am buying new valves, and wondered if i'm supposed to replace the old valve guides when you get new valves?.
Old Apr 8, 2002 | 01:16 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's a good idea... you can either replace the whole guides with bronze ones, or get the thin bronze bushings pressed into the existing ones. Either way, they'll last a whole lot longer than the stock cast-iron ones. Make sure that you get the top of them machined to .500" or .530" outer diameter so you can use the Teflon seals, which you can get from Crane or Comp. .530" is more common.
gta90
Sep 15, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
