Canister Questions
Old Apr 12, 2002 | 11:50 PM
VampireHunterC's Avatar
Canister Questions
The little black canaster in the front right is not hooked up. I forget what it is called, but it is supposed to get rid of gas fumes, correct? I have not had a problem with gas fumes; the only time that I smell any gas is when I am running the car hard, but that could be from the carb not running right. (problem with the secondaries not working). SHould I be worried about the canister not being connected? It looks like the line from the gas tank is still intact, but the line to the carb is gone, and the fitting on the canister is broken.
Old Apr 13, 2002 | 12:50 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
No don't be worried about it, it is just for emissions. It releases the pressure from the gas tank into that charcoal canister instead of the atmosphere. When you are using the car gas vapours are drawn from the canister into the carb or manifold. I removed mine a year ago, along with the rest of my emissions crap! But i don't run any computer controlled equipment.
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
redmaroz
Aug 16, 2015 11:40 PM
