Torque Convertor/Stall question
Old Apr 14, 2002 | 01:36 AM
ORAY777's Avatar
Would buying an aftermarket High performance Torque Convertor
make any improvements in my quarter mile times? I basically have a stock car accept for a few bolt-ons. I'm sure it would work for the higher horsepower cars but will it make an improvement on a basically stock car. I see advertisements advertising 1/2 second decrease in quarter mile times?
1991 Z28 1LE 5.7 Auto.
Old Apr 14, 2002 | 01:47 AM
rezinn's Avatar
I've seen otherwise stock LS1s in the 12s with an aftermarket torque converter, but that is an LS1. I know that the stock torque converter on our cars leaves a bit to be desired. So yes, you'd see a good improvement. Half a second? Maybe.
Old Apr 14, 2002 | 04:46 PM
ORAY777's Avatar
How do you know what stall to use?
Old Apr 14, 2002 | 05:15 PM
Morepower383's Avatar
Yes a stall converter will DEFINITLY help lower your ET's...Usually the things that determine which size converter to go with are the modifications made to your car such as a bigger cam, bigger gears, headers, exhaust, compression, and if your going to use nitrous... The best thing to do is call a company like ATI or Pro Torque and see what they recommend.
Old Apr 15, 2002 | 02:40 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
*exerpt from calgarydragracing site*
Here are some general guidelines for selecting a converter:
According to B&M, the stall speed should be rated at about 500-750 RPM under your engine's peak torque RPM. If you don't know this figure, be conservative in your estimate. You don't want to end up with a converter that has too high of a stall speed. Don't be too conservative, though - it is possible to get a converter with too low of a stall speed, which will have roughly the same effect as too high of a stall speed.
Know your camshaft specifications. If your cam has less than 220 degrees duration (@ 0.050" lift), which most street machines do, you make most of your torque down low in the RPM range, and you probably won't need more than a 2500 RPM stall speed, if even that much.
Have a good idea of your vehicle's weight. Remember, lighter vehicles will lower the rated stall speed; heavier vehicles will have the opposite effect.
High stall converters generate a lot of extra heat. The installation of an external transmission cooler is mandatory with a higher than stock stall speed converter. Actually, you should have one in there anyway. Heat is the number one killer of transmissions - 85% of all trannies die because of inadequate cooling.
The best advice I can give anyone buying a converter is to talk to the manufacturer. They know torque converters better than anybody, and can help you to select exactly the right converter for your combination.
:rockon:
for more info goto http://www.calgarydragracing.ab.ca/ and click on 'tech tips'
84z96L31vortec
Aug 20, 2017 12:16 AM
Horridbulldog
Wheels and Tires
Feb 13, 2016 07:22 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
gwade12
Aug 8, 2015 08:17 AM
