Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
1/4 mile question
Old Jun 19, 2005 | 08:48 PM
transam32's Avatar
1/4 mile question
what kind of 1/4 mile time would an 84 trans am pull with 500hp engine 700r built tranny 10 bolt built rear with 4.11 gears torque arms, ladder bars, subframe connectors, competition shocks, and with mickey thompson et drag radials. ????
Old Jun 19, 2005 | 09:19 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
what is the specific hp and tq on your entire rpm range? look into desk top drag and desk top dyno if you enter all the info into both correctly it will give a very good est.
Old Jun 19, 2005 | 09:32 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
hard to tell, 500hp on motor is alot.. i would say low to mid 11's at 120ish
Old Jun 19, 2005 | 09:50 PM
84firebird383's Avatar
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
Re: 1/4 mile question
If you have ladder bars you won't need a torque arm.I would also guess a low 11 second time.Don't forget a good converter for that combo.
Old Jun 20, 2005 | 05:22 PM
transam32's Avatar
yea that is what i am hoping the car will run when i am done with it.
Old Jun 20, 2005 | 08:34 PM
stroked1990RS's Avatar
Car: 1988 formula 350
Axle/Gears: 373
Old Jun 20, 2005 | 09:32 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
I say you pass the 11th grade first...
Old Jun 20, 2005 | 09:37 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
...What I mean is, I don't get it.
With 500hp, you should be in the 12's AT LEAST! That is with the right traction and the right driver.
Old Jun 20, 2005 | 10:04 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Old Jun 23, 2005 | 12:06 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 7, 2015 03:08 PM
