Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
Whats better to do
Old Sep 11, 2006 | 09:15 PM
Denial's Avatar
Car: 84' z28
Engine: Built 350 SB 4 Bolt, Bored .30 Over
Whats better to do
I have a 700r4 automatic, in an 84 z28, i can go 1,2,3 then drive... my question is.. what is bettert to do for a faster acceleration in a race atmosphere, shift manualy 1,2,3 then drive or just leave it in drive and pedal to the metal, also what rpms should i shift into each gear? Its a 350 sb and is only about 1000 miles old now with proper break in on both the tranny and motor.
Old Sep 11, 2006 | 09:34 PM
CrazyBear's Avatar
Car: 1987 Camaro,'89 firebird
Engine: 305 quadjet, 305 tbi
Axle/Gears: 2.73. 3.2xs
Id say go with whatever your more comfortable with.
Old Sep 11, 2006 | 09:35 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
7400 RPMs
Old Sep 11, 2006 | 10:06 PM
lilbowilson's Avatar
Car: 87 IROC
Engine: 406 sbc with Trick Flow heads, Hook
Transmission: Pro built 700R4
Axle/Gears: waiting on a new rear!!!!
Originally Posted by brodyscamaro
7400 RPMs
OK that was a little funny.
Do you have a shift kit or a corvette servo? If not get'em that will make shifting it manual a little better and also get a B&M shifter its easy to install. What are the specs on your engine? If you have a average built 350 5500 rpms should be your shift points.
Old Sep 11, 2006 | 10:19 PM
Denial's Avatar
Car: 84' z28
i already have a steet /strip kit in, with the b&m shifter with the lockout on it, just curious whitch method is better for faster acceleration if it even makes a difference
Brody, thanks for the smartass comment, it really helps everyone around here actually trying to learn something
Old Sep 11, 2006 | 11:02 PM
Well, I'll help you as soon as you answer libo's question.
Engine specs play a role in the RPM at which you should shift.
Old Sep 11, 2006 | 11:45 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Hold it in first till you launch then shift it to third. That's what I did in my TA, just to make sure that it wouldn't go into second.
Shiftpoints depend on your setup. What heads/cam/intake/exhaust/gears do you have?
Old Sep 12, 2006 | 05:08 AM
Blu91Z28's Avatar
Car: 1991 Camaro Z28
Engine: TPI 5.7 L
Transmission: 4L60 w/Vigilante 2,400 Stall
Axle/Gears: Girdled 10 bolt/3.23's
A stock 700R4/4L60 should not be manually shifted at WOT. It takes a second or two for the line pressure to rise so it can shift to the next gear. In other words, you'll end up over revving everytime. Just leave it in drive and mash it. If your shift points are not where you want them to be, you'll need to buy a spring and weight kit for the Governor. Do not use the TV Cable to try and adjust your shift points either! Very bad idea!
Old Sep 12, 2006 | 09:21 AM
Noize's Avatar
Car: 2003 Evolution VIII
Engine: 2.0 I4
This is true. I used to overrev my L69 '84 that way.
Old Sep 15, 2006 | 10:54 AM
Denial's Avatar
Car: 84' z28
It isnt "stock" though, it was built by mad dog transmissions ( maddog-transmissions.com ) and has a street / strip kit along with aftermarket mounts and some other small things, so does that make a difference in manualy shifting at wot? Or could i just left off the gas for that fraction of a second alittle to shift to the next gear and would it still be better then just throwing it into 3rd or d to let it go on its own
Old Sep 15, 2006 | 05:06 PM
I always shifted mine manually... The tranny survived longer then I thought it would...
Old Sep 15, 2006 | 06:11 PM
Blu91Z28's Avatar
Engine: TPI 5.7 L
Does it instantly shift to the next gear or is there a second or two delay? I have a Trans-Go Valve body kit in mine and it still does it. Like I said above, if it's not shifting at the RPM you desire, all you need to do is buy a kit to change the springs and weights on the governor. It's an easy job. The governor is located on the driver side of the trans. It has a stamped steel dome shaped cover. You can't miss it. The other thing you can try is snagging a couple governors out of the junk yard. Different engines had different RPM ranges hence different governors with different springs and weights. Good Luck!
Old Sep 15, 2006 | 08:00 PM
91drag's Avatar
Car: 1928 dodge coupe, 64 1/2 mustang
Engine: 350,289
Transmission: munice 4 speed,c4
Axle/Gears: 9" 3.00, 9" 3.25
[QUOTE=Denial;3061276]It isnt "stock" though, it was built by mad dog transmissions ( maddog-transmissions.com ) and has a street / strip kit
good luck with that trans might need to read post about them in vendor section
https://www.thirdgen.org/forums/afte...ht=maddog+long
Old Sep 16, 2006 | 09:22 AM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
He never answered the original question pertaining to the cars specs.
Old Sep 22, 2006 | 10:58 PM
piratexcore's Avatar
Car: 89 Trans Am GTA
If theres a delay in the shift when you manually shift, leave it in drive. If it shifts hard when you manually shift with no delay, you can shift it yourself. Go to a track and test which rpm is the best to shift at. Honestly though, it wont make that big of a difference and you'll probably end up wearing out your transmission which happens a lot of fbodies that people manually shift.
Old Sep 23, 2006 | 03:53 PM
84L69TA's Avatar
Car: 4 Mopars total
LOL, I dont know about that. Ive had 12 thirdgens, and have been racing them regularly for 9 years. I never had one problem. In a lot of transmissions, it actually increases line pressure...which means good. I dont remember if the 700R4 does (its been a while since ive been into one), but TF 904's and 727's do, as do the TH350's and 400's.
Old Sep 23, 2006 | 11:06 PM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
Leave it in D.
You don't like it, get yourself a manual. Really.
Old Sep 23, 2006 | 11:37 PM
Eh, I manually shifted my 700R4, and it went out in less than a year. The guy that rebuilt it said that its pretty common and I was lucky mine lasted as long as it did.
Edit: My GTA was error proned anyways, so I was probably just unlucky again.
