87 Transam vs 92 Corvette
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Alright guys.I got a lil bet going on with my fellow boss/bestfriend who is older and can drive really well that from a dig i might just beat him on a light to light race and i want some honest opinions on what the outcome might be provided i hook well.
His car is a 92 LT1 vette.bone stock motor with magna muffler and C5 18 Zo6 rims.6 speed.
Against my car.mods are in my sig.
Now here is the catch.He has the infamous lt1 distributor moisture issue that makes the car bog hard around 4500rpm and up cutting his powerband down.His car also has traction control so who has the better shot in this close race.Im close to nailing my launches to minimal wheel spin.
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
Re: 87 Transam vs 92 Corvette
Engine: 2005 LQ4
Axle/Gears: 3:54
well i do know his car runs perfectly fine untill it hits higher rpms.it does it all the time thats a fact.on a good day it may not bog so early..as in around 5-5500rpm and then it sounds like someone was bouncing off a rev limiter.other than that i feel the car is solid when i drove it.
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
BTW- after some dragstrip practice i coaxed a 13.3 at 107mph out of my bone stock 93' 6spd Vette... if he can truely drive you may be in trouble
Engine: 2005 LQ4
Axle/Gears: 3:54
yes thats exactly his problem.the opti spark.and his asr has a malfuntion on it since he can no longer swith between suspenion settings.but yes he can drive very well and i know it will be close and he will probably edge me out but as of yesterday we retired the car due to the rear diff blowing out as we pulled into the driveway to our shop.i was excited for this matchup and now he is going to dump money into it before i can race him stock.
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
I think the trans am guy will be bowing down to the vette owner.
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
if you are running street tires.....i think he will get you out of the hole imo. but then again i could be wrong......i think this will be a holeshot race....
the_hamturdler
Sep 30, 2015 12:50 PM
