Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
84 ta 1/4
Old Apr 19, 2008 | 10:08 AM
racer rick's Avatar
Car: 68 firebird,84 ta,84 short box,
Engine: 350,305,350
Transmission: t10,700,350
Axle/Gears: 323,410
84 ta 1/4
any geuss what my ta would do in the 1/4? 305 bored 20 over forged flat top pistons edelbrock rpm cam ,intake,250 shot ,2800 stall converter ,323 ratio
Old Apr 19, 2008 | 11:34 AM
camshaftxe's Avatar
Car: 91 rs
Engine: tbi 350
Transmission: 700r/manual
Re: 84 ta 1/4
250 shot? Wow, thats huge you sure you not going to hurt those pistons?
Old Apr 19, 2008 | 11:52 AM
DirtyCanadian's Avatar
Re: 84 ta 1/4
you may want to have a backup engine lined up for when that one blows.
Old Apr 19, 2008 | 10:46 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Re: 84 ta 1/4
What cam, what intake manifold, what's your compression?
I'm going to say your ET will be however long it takes the tow truck to tow you after you grenade your motor on a 250 shot.
Old Apr 20, 2008 | 11:01 AM
billybird's Avatar
Car: 89 Formula
Engine: LB9 TPI
Axle/Gears: 3.73(coming soon)
Re: 84 ta 1/4
you should have forged connecting rods aswell with a 250 shot but good luck man
Old Apr 20, 2008 | 11:46 AM
lilbowilson's Avatar
Car: 87 IROC
Engine: 406 sbc with Trick Flow heads, Hook
Transmission: Pro built 700R4
Axle/Gears: waiting on a new rear!!!!
Re: 84 ta 1/4
All connecting rods are forged what kind of steel in those rods is what matters. If there stock I dont see it lasting long but if there rated at 500+ I don't see a problem. I've see a lot of stock crank shafts handle a 200 shot as long as you have good quality bearing, head gaskets, and pistons rings it should hold up but not forever. My guess is (If your suspension is right) 11.8-12.2 1/4mile.
Old Apr 20, 2008 | 12:20 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Re: 84 ta 1/4
If you can build the engine to take a 250 shot, you're gonna blow out the rear end the first time you launch on the gas. You need to seriously consider the driveline along with the engine build and tune if you're thinking of running a 250 shot. Gonna need to know the baseline HP before we speculate on what you could run... I'd say anywhere from low 11's to mid 12's.
RedLeader289
May 28, 2019 01:47 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Vincent135
Sep 28, 2015 10:50 PM
