View Poll Results: Which wins in stock trim
LS1
19
44.19%
LC2
16
37.21%
Drivers race
18.60%
Voters: 43. You may not vote on this poll
TTA vs LS1 ONCE AND FOR ALL!
Car: ws6
Engine: ls1
Transmission: m6
Lets settle this. Which car is faster? Post articles to prove your point. Lets keep this a friendly debate please. I think an LS1 car would win from a dig and roll. Your turn.
1998-2002 M6 Camaro SS or Trans Am WS6
310-325rwh Roughly 350 Flywheel
1/4 12.8-13.1
89 TTA
250wrh 300 Flywheel
1/4 13.4-13.7 Best I could find.
http://www.popularmechanics.com/auto...6.html?page=11
http://www.stangbangers.com/01_Bullitt_Article2.htm
EDIT- MISREAD ARTICLE
1/4 12.8-13.1
89 TTA
250wrh 300 Flywheel
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
Re: TTA vs LS1 ONCE AND FOR ALL!
1/4 12.7-13.1
89 TTA
250wrh 300 Flywheel
1/4 12.7-13.1
89 TTA
250wrh 300 Flywheel
edit: ahhh, i see. the mag did mention evans run, and mused that their 01' test car MIGHT have gone 12.7s in better air. but it didnt, and this test is only about what DID happen, not what COULDVE. keep it factual please
regardless, i doubt any TTA ever hit 12s 100% bone stock. might want to check www.turbobuick.com for more info on the TTAs
Car: 89 20th Ann. TA
Engine: Turbo 3.8 V6
Transmission: 200 4R
There was supposedly a "stock" TTA that ran 12.9 back in '90. But they are so easy to make fast, its anybody's guess how stock it really was. Mine ran 13.0 with just a t-stat and Thrasher92 chip. Had all of $30 in mods
The only time I had mine dynoed, it made 318/455 to the wheels. That was with the Thrasher92 chip, t-stat, 8" K&N, adjustable wastegate, cat pipe, and Nittos. Ran 12.1 that weekend also.
The TTA is decieving because it makes big block torque with low hp numbers.
As far as the question, it's a toss up from a dig or roll. The TTA is consistent, run after run, as any car I've ever owned.
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
i would think to keep things fair and equal, apples to apples if you will, it should be an auto LS1 tested against a TTA. after all, the TTAs couldnt be had with a manual trans
on stock cars, a well driven manual trans is always going to be quicker than its automatic counterpart... thats an advantage the TTA doesnt have
whats the best bone stock auto LS1 fbody time?
Probably on par with what Pontiac said the TTA would run in the brochure...13.4
Car: ws6
Engine: ls1
Transmission: m6
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Well, if your talking right off of the showroom floor, untouched, than the LS1 will win. But if you allow both cars to run drag radials, any stall, trans brake, and allow for the LC2 to up it's boost, the LC2 will annihilate the LS1. My buddy Scott (Murpshter on TurboBuicks.com), just went in the high 11's with a stock LC2 @ 22-psi in his Grand National, in fact, there are a lot of guys running even better than that w/their stock turbo buicks on those boards. But again though, if your talking right off the showroom floor, gotta go with the LS1....
Car: ws6
Engine: ls1
Transmission: m6
Even better, I have the video. I also have a video of another's Grand National running 10.98 w/just a T49 turbo (one step up from the stock turbo). I didn't download Scott's turbo buick on streetfire yet, I still need to rip them from the disc, but I do have some video's of TTA-850's ride hauling *** down over at e-town since we're talking Trans Am's....
http://videos.streetfire.net/video/T...LC2_642131.htm
http://videos.streetfire.net/video/T...LC2_642132.htm
.... here's my buddy Paul's Grand National running with a stock engine, all factory cast. His runs are first and last, has over 400 PASSES with just cast parts;
http://videos.streetfire.net/video/e...8c013e4547.htm
.... and, to make this fair, here is my buddy Shawn's old GTA w/stock LS1 swap (75 shot);
http://www.youtube.com/watch?v=U88OC...e=channel_page
Car: 87 GTA
Why bring up Grand Nationals? The TTA got different parts (like the heads), so the Grand National (nor GNX) is even a valid stand in for a TTA.
BTW, the TTA may have been RATED by GM at 250hp (the official GM degree was "Nothing we make, makes more horsepower than the Corvette"), but independent dyno tests, right off the showroom floor, showed they commonly put out 301hp at the rear wheels.
Fun times...
The "official" rating had nothing to do with the 'Vette as it was rated at 255HP that year(I think). It was to warranty the 200 4R. Hydromatic wouldn't warranty it if it was rated higher.
Originally Posted by Stephen
Why bring up Grand Nationals....?
Originally Posted by TTA 1387
I can believe a hi 11 on a stock LC2. Mine went 12.1 with 18psi. That was stock everything, even the converter. Still managed a 1.69 on Nittos. The injectors were at 110% DC also. After that is when I put on the mods. A converter really helps the launch. I was literally coming out of the seat trying to hold the stock converter.
Fun times....
Fun times....
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
in 1986, the Corvette was rated at a MAX of 235hp (aluminum headed late model year cars). when the 86' first appeared in showrooms, though, it was only rated at 230hp. Buick played some advertising games with chevy and made the 86' GN 5hp more than the Corvette, making the Buick's rating 235
then for 1987, the Corvette upped its rating to 240 due to the addition of roller rockers. again, Buick played games and rated its GN 5 more hp for a total of 245
finally, in 1989, the Corvette was rated at 245hp when the optional gear ratios were installed. This time it was Pontiac playing the games, and advertised the TTAs at 250hp... again, 5 more than the best Vette offering
so you see, the whole "nothing shall eclipse the Vettes power" myth was shattered every year the intercooled Buick mill was offered. i have to remind you guys of that everytime a thread like this is brought up. lets try and remember it this time
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
you dont need to give the LS1 an advantage like a manual trans over the little 6 cylinder do you? stock vs stock. stock tires, stock boost. auto to auto (which would also put the rear gear ratios near identical as well) i believe would be the most accurate to say which ENGINE is faster
Car: 87 GTA
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
edit: got bored and did a quick search...
post #35
https://www.thirdgen.org/forums/theo...v-s-turbo.html
and here at post #37... see how im getting a bit annoyed with repeating myself?
https://www.thirdgen.org/forums/theo...ls1-trans.html
Car: 87 GTA
the Buick has 2 less cylinders. and is running with over a decade older technology. and has a cylinder head design that dated back to the 70s, while the LS1 was designed using the latest computer simulation models. and you think the LC2 has an advantage?
you dont need to give the LS1 an advantage like a manual trans over the little 6 cylinder do you? stock vs stock. stock tires, stock boost. auto to auto i believe would be the most accurate to say which ENGINE is faster
Imagine if the TTA V6 was redesigned with 21st century technology from the ground up.
Yeah, I'd say the LC2 wins.
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
Everything being equal I think the LS1 car should win but not by much at all and in some cases wont. Back in 2005 I was in GMHTP shootout of stock cars and while I had a fuel pump issue that slowed my car down to a 13.71 @ 97mph, it has gone 13.37 @ 104mph in similar conditions on the same track after replacing the failing fuel pump BTW
. There were three LS1 cars there, a 2002 CE Trans Am that went 13.44 @ 106, a 1998 Trans Am WS6 that went 13.54 @ 106, and a 2001 10th Anniversary Firehawk that went 13.83 @ 103. So even with a failing fuel pump I beat one LS1 car and was very close to the other two, and should have gone quicker than them if the fuel pump had not gone away. This is in the December 2005 issue of GMHTP, my TTA is on the cover next to a GNX and the rest of the shootout cars
So with that said I think it would be very close, and I think in ideal conditions a TTA can get close to a 12.99 run bone stock, and has the power to do so, but stock tires will probrobly limit the car to very low 13's. Now give me $1000 worth of mods, including gas and tires, and I'll get you high 11's at 112-113mph. My old car (#861) went 11.99 @ 112.26 on a 1.63 60ft with a failing transmission and converter (wouldnt lock up and would slip on WOT shifts), mods were K&N Filter and steel inlet pipe, test pipe with dump, adjustable wastegate actuator set to 22psi, Thrasher 108 chip, 112 octane race gas, and M/T ET Street 26x11.5x16 tires on stock GTA wheels
http://img.photobucket.com/albums/v2...0/1199slip.jpg
http://smg.photobucket.com/albums/v2...1-1199-112.flv
Car: 1991 Formula Firebird
Engine: L98 with headers/exhaust
Axle/Gears: 3.23 10-bolt
Great race for sure in stock form! I've never seen a 100% stock TTA at the track, but did see a stock to the factory air-filter 2001 TA run a 12.9@106 at GL Dragaway back in 2003. Throw $500 in mods at both cars and the TTA is a clear winner...
Car: ws6
Engine: ls1
Transmission: m6
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
to find out which engine (LC2 vs LS1) is faster itd be best to determine the outcome with everything being as equal as possible. apples to apples
How is a power adder not an advantage? Just sayin both cars have their advantages.
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
bottom line is this:
LS1/auto vs TTA: identical E/T and mph figures
LS1/manual vs TTA: LS1 wins in both E/T and mph numbers
like ive been trying to point out, the ENGINES will perform the same stock vs stock at the track. the determining factor will be the LS1s ability to utilize the manual trans. So neither ENGINE is "better" or "faster" stock for stock
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
same enlightenment came over me when i pulled off a Crossfire intake manifold. its like the engineer was on crack when he made the intake ports HALF the size of the head ports
there certainly was something wrong with the talent over at GM during the late 70s/early 80s. well... they DID slap a turbo and intercooler on a 3.8 during those years, so maybe a few werent so bad
Car: ws6
Engine: ls1
Transmission: m6
the LC2 motor came with a turbo from the factory... no one added one to it, so its power adder is not an advantage. it came that way. 100% bone stock. if the boost were increased, then THAT would be an advantage, but were talking about 100% factory stock motors, and the fact of the matter is, the LC2 HAD a turbo. you couldnt order a TTA without the turbo, its power adder wasnt an option (like a manual trans WAS on a LS1 car)
Car: 1991 Firebird
Engine: 3.1L V6
. It doesn't matter IF you had it, what matters is that's how it came from the factory. Thread Starter
Car: ws6
Engine: ls1
Transmission: m6
This should not be viewed by which motor is better, but which car. The LS1 car was designed to be all motor, the TTA was designed to utilize the turbo, that's what that motor was made for. So giving the edge to the LS1 just because it was designed all motor doesn't make it a clear winner. That's just the same excuses used by many, "if my v8 had a turbo"...or "if i had 2/4 more cylinders or bigger displacment"
Car: 87 GTA
Any way we can just SETTLE it?
Find a low mileage of each....We'll even choose a 2002 LS1, since it would be the "best" factory FACTORY (no SLP stuff) version of LS1s.
Run 3 outta 5.....No slicks, no soft compound tires.....Winner gets the "trophy".
Car: ws6
Engine: ls1
Transmission: m6
An LS1 is an LS1. Only a 5 hp difference between the cars. The fastest one was actually a 1999 Z28 that ran 12.85.
Car: 87 GTA
Originally Posted by 89IrocZ350TPI
An LS1 is an LS1. Only a 5 hp difference between the cars. The fastest one was actually a 1999 Z28 that ran 12.85....
Car: ws6
Engine: ls1
Transmission: m6
2002 Pontiac Trans Am WS6 LS1 346 V8 325 13.5
98-00 used a more radial cam I believe. 01-02 had LS6 intakes and a better shifter. Strange that the 99 NON SS was the quickest.
Car: ws6
Engine: ls1
Transmission: m6
Yes but that LS1 was setup to run that 12.85 ET. To go all out with a stock as a rock TTA, all you'd have to do is up the boost, because GM obviously detuned them from the factory so nobody would kill themselves on their way from the dealer. Stock for stock, w/the stock rims and tires, allow the LS1 to be dyno tuned, and allow the TTA to run upwards of 20+psi, and the TTA will eat the LS1 alive....
I dont understand what you mean by setup. I believe it was the same car they used in the mustang article I provided.
Car: ws6
Engine: ls1
Transmission: m6
I don't go by articles in magazines. If I'm not there, I simply won't believe it based on hearsay, and this goes for "Ranger's" infamous 10 second run with a stock Z06. I own a '98 Trans Am w/LS1, and never broke 12's with it, stock. I came awfully close with just a set of drag radials and a tune (set up), but still no cigar. Once the stall speed converter went in, as well as the SLP lid, I broke 12's no problem....
I never heard of an auto ls1 getting 12's so I am not surprised. I plan on running my M6 w/cat back and K&N's some day but right now with 22,000 miles I dont want to race it just yet. I want a high 12 as is, then full bolt ons would be fun....
Car: ws6
Engine: ls1
Transmission: m6
You'll get there. Sticks are very fun, but I would never take one over a stalled automatic w/transbrake under boost. I was just like you once upon a time, didn't buy into all of that turbo V6 crap, until I got freaking smoked by one at the track. Got so hooked on them that I gave the LS1 to my wife, here was the last day it was officially mine, just before leaving for the track (now she won't let me even breath on it, let alone drive it lol)....;
When you get into boost, it is an entirely different story. Throw a turbo on an LSX, and you better hold onto your hat. Here is an 8 second Trans Am, running on a 17" drag radial, that drove to and fro the track. Now this is unreal, and I don't see any turbo buick (including the TTA) coming close....;
http://www.youtube.com/watch?v=yLXu6BXT9Q8
http://www.youtube.com/watch?v=rkoUMkD93q4
Car: ws6
Engine: ls1
Transmission: m6
After I sold the WS6 and had just the TTA, I got lots of weird looks from people at the track. Even guys from EFA kind of snickered at it. Then they saw it run and some really got behind the little V6 TA. It's amazing how many people have no clue what a TTA is.
Lots of fun that car was. Low 11's at over 121mph...leave the track with the A/C on and still get 28mpg
You just can't beat that. Supreme Member
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Why does everyone think EVERY f'in LS1 runs 12's? They DON'T...FAR from it. A "few" have managed to pull it off but is NO means the norm.
More typical LS1 ego BULLSHIT. Sorry but a '99 Z28 isn't going to consistently run a 12.8x...isn't happening....they're all mid-low 13 second cars with some factory freaks/ridiculous drivers.
...and for the record I've owned 2 LS1 cars...neither were 12 second cars in stock form.
Car: ws6
Engine: ls1
Transmission: m6
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
I see this thread going overboard already but here is my opinion and this was supposed to be comparing "apples to apples" not the best of the best run that had the best drivers etc.
To make this a 100% fair poll you have to take a ls1 car thats fully optioned..full tank and auto up against a fully optioned full tank of gas 89tta stock for stock.This way no one argues about what trim the cars are in for weight advantages etc.This race would be extremely close from a dig and possibly from a roll.Should be a drivers race.
And to all the guy that praise the ls1 so highly I ask this question.Why are we having this poll if the TTA wasnt still a potent engine in stock form or modded.It might be older technology but it still works great to this day.My vote is drivers race...neither is better than the other just prefference in type of car you like.Both are fast either way..both can be made faster for cheap and parts are readily available.Pick your poision and rip up other cars and show gm pride.
