89 IROC 350tpi vs 08 Mitsubishi Lancer
Car: 1989 Camaro IROC-Z
Engine: 5.7 350 TPI
Axle/Gears: 2.77
i know a kid from my school who has a all wheel drive 08 lancer with a (according to him) single spool turbo.. he said it has 250hp... i have a 89 iroc rebuilt 350tpi all stock except for a shift kit... from a standstill, who do you think would win?
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Re: 89 IROC 350tpi vs 08 Mitsubishi Lancer
Hope your not a sore loser, no offense but from a dig especially...you dont stand a chance with him being awd.And from a roll isnt where a tpi likes to shine either.if the kid can drive and launches hard then you cant win.If you dont spin and get a good hard launch from a dig..you may be able to put some distance on him and edge out a win...a very close win. Good luck and be safe.
Car: 92 trans am ws6
Axle/Gears: 3.42 ls1 rear end posi
yea lancer accelaration is high with all wheel drive..and turbo
goodluck
goodluck Member
Car: 1989 i roc-z28
Engine: 350 tpi l98
you will need some mods done if he a good driver
Car: 1991 Trans Am GTA
Engine: 355
Transmission: 4L60
Axle/Gears: 4th gen 10 bolt 3.42 posi
There were 2 types of turbo lancers in '08, the Ralliart and the Evo. The Ralliart, which I suspect this kid is claiming to have, is rated at 235 HP in '08 last I heard. Go out and take a peak at his car sometime and see if you see a Ralliart emblem on it anywhere. You should be able to run with him in all honesty as they seem to run mid to low 14's from the factory which is completely doable in an L98.
Check out some timeslips for them: Lancer Timeslips
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
AWD also makes the car a lot heavier. It's most likely a Ralliart, don't know how wealthy your community is but Evo's ain't cheap. It may very well come down to who a better driver. I beat a Porsche 944, but just because the punk-*** kid couldn't drive daddy's car.
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
Don't be afraid of AWD, it just means they put down even less to the wheels!
...just kidding, any turbo AWD car should scare you because they can fully spool and launch.
1989formula5.7l
Aug 15, 2015 11:35 AM
mustangman65_79
Aug 11, 2015 03:17 PM
