82 z-28, vs 89 iroc lt1 swap
Car: 1982 Z28, 1991 RS
Engine: 350 Carbed, 305 TBI
Transmission: 700r4, t5
Axle/Gears: 3.23s posi Limited Slip, 3.08 posi
1982 Camaro z28 it has a mildly built L98 350 vortec heads, mild cam, high performance high rise holly intake, high performance holly 600 cfm carb, 8. mm spark plug wires, b&m mega shifter,2.73 possi limited slip rear end,headers, A/C & smog Delete, 700r4 trans, and 245s on the back.
My brothers, 1989 camaro z28 lt1 swap, 4l60E trans, 3.23 gear open diff, 275s on the back, bone stock. Both cars run good, an were pretty good drivers. Who will win from a dig and a roll?
Car: 1982 Camaro
Engine: 427 BBC
Transmission: Turbo 350
Axle/Gears: Stock rearend
Re: 82 z-28, vs 89 iroc lt1 swap
I thing the 82 would pull it off its a little bit lighter than the 89 and it sounds like you have a pretty good motor in that 82 LT1 where only like 285HP and 345TQ stock if i remeber correctly
Well, im not for sure, but the owner told me it had a mild cam, the idles kinda choppy and it revs sh*t quick, and turns some rpms. I have a 2.73 rear end possi in it for now, how bad is this rearend holding me back?
mustangman65_79
Aug 11, 2015 03:17 PM
