Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
Whats the TOPSPEED of a 92 Firebird, 305 TBI?
Old Jun 7, 2001 | 05:49 PM
One Eyed Jack's Avatar
I'd like to see
1992 Pontiac Firebird (stock)
- 5.0L V8 TBI / Automatic Trans / Every option, excluding leather
- Killer car audio system:
  • Aiwa CDC-MP3 head unit
  • Rockford Fosgate 360a2 amp
  • pair of 12" MTX Thunder 5000s in a custom box
  • Pioneer 3-way 6x9s, soon to add more more more!
Old Jun 7, 2001 | 09:55 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
try the "equasions" forum,you probly have 2.73 gears , and you need the radius of the rear wheels. the transmission gear ratios are listed in the tables and you shouldn't wind too much above 5500rpm.
Old Jun 7, 2001 | 09:58 PM
TriGenRS's Avatar
If you havent messed with the limiter...then its 108-112MPH (Computer Limited). With it removed I would *guess* about 130
Old Jun 7, 2001 | 10:02 PM
Okay two questions:
1. What would i enter for Transmission Gear Ratio for my Automatic 700r4 ?
2. The limiter is the GOVERNOR right? How do i tweak that?
Old Jun 8, 2001 | 12:08 AM
Engine: 2.2
the computer will do the math for you, .7 is the overdrive ratio for the 700r4.
Old Jun 8, 2001 | 12:46 AM
bubbz89's Avatar
Car: 1990 RS
Transmission: TH-350
why dont you get on the highway and finid out?
bubbz89's Avatar
Car: 1990 RS
get on the highway and drop the hammer.
Old Jun 8, 2001 | 12:24 PM
91Firecrow305TBI's Avatar
There is a tech article on this board for bypassing the governor. Look in Technical Articles.
Flowmaster 80 series muffler
K&N Open Element cleaner
Ultimate TBI Mods
Subframe Connectors
GM Wonderbar
lead pedal foot . See my project rocket turtle @
http://oursportscars.homestead.com/home.html
Old Jun 8, 2001 | 03:41 PM
92heritageZ's Avatar
i tried that calculator and it says i can go 170 mph at 5000 rpms... surely that isnt right.
1992 Heritage Z/28
5.7 TPI
Auto Tranny
White w/red stripes
Factory Rear Window Shade
Grey Leather Interior
Alpine CD w/alpine's all around
2 12' subs in custom "camaro" box in trunk
G92 performance package w/ a/c
Flowmaster exhaust
only 14k miles on her!
1999 Ford Ranger Sport
2.5l I4
5spd
ram air w/ k&n filters
Daily driver
Old Jun 9, 2001 | 11:54 AM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
If our cars have a speed limiter how come I can get mine up to 140+ in 4th gear?(92 TBI 5.0 5-speed) Did some come without the limiter?. And 92heritageZ just because the calulator says you can go 170@5000 RPM does not mean you have enough horsepower to do it.
92 Camaro RS 5.0 5-Speed
14" Open Air Cleaner
3.08 Posi-trac
Edelbrock TBI Intake
Crane cam
Ported & polished stock heads 3 angle valve job
HyperTech Chip
SLP Headers (Ceramic Coated)
UltraFlo cat-back exhaust
74 Dodge Dart Sport 360 (11.2 1/4 mile)
2000 Dodge 1500 Ram Sport
Old Jun 9, 2001 | 06:50 PM
Engine: 2.2
get a ruler out and measure the RADIUS of a rear wheel (tread to rim's center). double check your gear ratio. I have 3.73s so I only go 108 tops,which doesn't bother me because I have no need to go faster than 108mph! with 2.77s which I had temporarilly,it didn't want to wind up more than 4000rpms in OD, ofcourse I was doing much better than 108mph by then!!
put : your redline rpm,your car should be able to redline in OD. radius of rear wheels and OD ratio: .7,and gear ratio
Old Jun 9, 2001 | 11:48 PM
Baron's Avatar
Somebody PLEASE help me with this one...
After destroying my 5th gear putting a clutch in wrong, the shop put a big 5th in...with my 2.73s, it equals...
2000 RPMS = 80 MPH
My question:
If I put in 3.27s or 3.42s or whatever those numbers are, what respective RPMs would 80 MPH be for each? Thanks a lot...
'89 RS LO3- 140,000 miles
14x3 K&N Open Element
Ram Heavy Duty clutch
Edelbrock TES (Jet-hot coated)
Catco cat
Edelbrock 3" Cat-back
Pioneer DEH-P77
Dual .50 caliber machine guns just under ground effects
Coming:
KYB shocks
Edelbrock Strut Tower Brace
South Side Machine subframe connectors
When your buddy reaches for a 10-pound sledge and says "I think we're gonna have to modify the floor pan, okay?" the answer is NO.
Glowsock
Jul 24, 2025 03:15 PM
xkingcodex
Feb 12, 2020 07:43 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
MENINBLK
Aug 5, 2015 11:58 PM
