Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
91 Camaro vs 69 chevelle
Old Apr 3, 2017 | 09:39 PM
"John"'s Avatar
Car: 91 Camaro RS
Engine: 350 crate engine 360ish HP
Transmission: T5 5 speed manual
Axle/Gears: 3.42 10 bolt POSI
Which would win in a quarter mile?
91 camaro
350/330 horse crate engine with cam zz4 springs roller tips headers and dual exhaust estimated 360 HP
T5 (2.95 first gear i think)
3.42 rear end POSI out 95 camaro
245 tires
I would guess the weight to be around 3600 with driver
69 chevelle
369 big block long tube headers and dual exhaust estimated horsepower 380
M22 4-speed "rockcrusher" close ratio (2.20 first gear)
12 bolt 3.42 rear end
275 tires
3800lbs with driver?
Old Apr 4, 2017 | 07:41 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: 91 Camaro vs 69 chevelle
All depends on TRACTION. My dad had an all original 1969 396 Chevelle SS and it was a torque monsterbut.. my old mid 13 sec GTA could outrun it simply because the heavy chevy would roast the tires. If he had slicks on it that wouldn't have happened.
Old Apr 5, 2017 | 03:43 PM
"John"'s Avatar
Car: 91 Camaro RS
Thats what I thought... I didn't know if any gear ratios would be a determining factor
Old May 20, 2017 | 11:15 AM
VTSummit's Avatar
Car: 88 GTA
Engine: 5.7
I've had a lot of cars, including an SS396 Chevelle. They aren't fast cars. They're ocean liners with some torque. Honestly, our memory of those cars is far better than the reality of them. It really came to light recently here locally as a freshly built 396 Chevelle with aftermarket cam, modern carb and headers etc lost to a 2016 V6 Camaro with a tune and cat-back... and not really by a 'little bit' either.
Old May 26, 2017 | 11:26 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
x2
stock big blocks of that era were pigs The low end tq made them feel faster than they were kind of like a tpi.
Old May 26, 2017 | 05:09 PM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
That Chevelle isn't built much different than my 71 GT-37 with it's 455HO, TH400 12 bolt. I've had a best of 13.23 in Pure Stock trim with 3:08 gears in the rear. I'll let you know how I do after this weekend with the 3:73 gears. I'm pretty confident the car is capable of mid 12's, just not sure the driver is.
Car scales at 3840 with me in it - should be 3620 car only and those times are with Firestone Wide Oval Bias Ply's.
