Headman long tube headers
Car: 87 IROC
Headman Long tube headers. Will work with cars that are auto and have no A/C. These won't clear your A/C box on the firewall unless you remove it or grind down the header flange. You can get it to work with a T5, but you will need to grind down a portion of your bellhousing below the slave cylinder location. They have slight surface rust from sitting on the car. Headers don't have much running time on them.
Asking $80 for the set. Will consider trades for carbed S.B.C or thirdgen parts. Looking for an aftermarket alum. intake manifold.
PM or email at kevin_vandevenne@hotmail.com
Car: 1990 GTA
Engine: L98 5.7 L
Transmission: 700R
Axle/Gears: 3.45 9 Bolt
You might want to check the classified ads on this board. The REIS has an Edelbrock intake for a pre-1987 sbc.
morrow
Jan 13, 2024 12:29 PM
92projectcamaro
Jan 18, 2016 08:00 AM
