http://members.cardomain.com/iroczz4
Check it out and lemme know what you think. Can anyone in the area recommmend a really good place to get my car painted. Some place that does REALLY good quality work even if they are not the cheapest.. Thanx
im not the brightest apple in the basket but did you get busted for doing a burnout?? OUCH MAN!!! when i do them i do them and then im outta there quicker then a jack rabbitt does his business so i dont get busted...
anyways.. i like what you have done to the roc...keep it up!!
iroc2nv
iroc2nv
Nice car... How is the idle with the ZZ-4 cam?? I am building an engine and was thinking about putting one of those cams in but I am worried that it might be too big..
It has a pretty loopy low idle.. right now I just have a stock ignition setup so it can idle ruff sometimes.. I just picked up a MSD 6AL, blaster coil, new plugs, etc etc so I figure when I do that big upgrade to the ingition that should make it idle way better. Oh yeah its fuel injected too so I dunno it might be worse if you go carb. I'm running the Lingenfelter Superram with the lower intake fully polsihed and ported.
