The headers are on but the car will not run. I've tried everything I can think of. It starts but then it just dies. It looks like i'm not gonna be there tomorow. Have fun with out me
acceld...
look at the main wire (positive) coming from the battery. going into the main wiring harness of the car..that was cooking when i got my headers done,they had to reroute the wire and its fine now..altghough i need a water bump..(oh well)...it could be the same thing..i know thats what the problem was with my car...
it would run then just die all of the sudden..
i wanna see you there man..
fix it and common down..
iroc2nv
iroc2nv
Hey accel! try dsiconnecting your battery for a few minutes, then try to start. Worth a try?
Also, check your vacuum hoses too. After porting the plenum over the winter, I hook everything back up except for the vacuum hose going to the brake booster...it would crank and start for a quick second and then die right away.
dohhh. thats sucks ***. we had so much owning to do. hehehehe
Jessuuus Chhrriisstt!!!!!!!11
Quote:
Wow.. your's would stall? I forgot to plug the Booster vaccuum too.. teehee... but mine just loped irratically.. kept running though. Almost sounds like a bummed MAF.. but I don't think you have a MAF anymore. right? So maybe a bummed MAP? Maybe the heat from the headers got to the fuel lines, and fried the fuel pump? Just throwing stuff out.... Had a similar problem with my '79 Parisienne, it was the whole distributor that was shot.. well, maybe not... but I just replaced it the whole thing anyway... I tried the module first, still nothing... so I imagine it was the HEI on the base of the distributor (I think thats what its called)Originally posted by IROCKER
LOL, nice try.... you never had me fooled!
Hey Nathan.... I got another one for your sig:
Q: What's the difference between BMWs and Porcupines?
A: Porcupines have the ****** on the OUTSIDE.
hahaha whered you get that? So true though BMW are more snotty than anyone you see. Saw somewhere that M3 only has like 182bhp... Isnt that like 160ish net hp? Man thats not much more than a damn civic. M3 roadster is a dif story though...300 something bhp could make that tin can fly.
