Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
FlyWheel
Old Jan 29, 2003 | 09:12 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
FlyWheel
What do you look for when buying a used flyweel?
Can you check it visually for stress cracks or should it be magnafluxed.
Also, about how much $ to get it resurfaced.
What's a good shifter for a t5 - if good and t5 can be used in the same sentence.
Thanx
Old Jan 30, 2003 | 08:03 AM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
I'd buy one used with the caveat that it survives some basic health tests or money back.
The machine shop will expose most issues during a re-grind. If possible ($$$) I'd have the new clutch assembly balanced together with the wheel about $75 last time I did it but that was some years ago.
I've heard alot of good things about short throw shifters on T5s in GMHP magazine (Oct/Nov ?) they are building a 3rd gen not sure whose product they used but they definitely raved about the quality of the unit and the improved shifting.
RP.
Old Jan 30, 2003 | 12:36 PM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
I paid $50 for a resurface last year.
Flywheel, maybe $50 for used.
As for the shifter, it was a Pro 5.0. I have one (T-56 version) and love it. Doesn't even compare to the stocker, this thing is awesome.
Powershifts are now made possible, stocker, no way.
Old Jan 30, 2003 | 06:16 PM
Ratchet's Avatar
The two things I would look for when buying a used flywheel would be deep qouges that would prevent it from being resurfaced (Check for minimum thickness stamped on flywheel) and the ring gear. Make sure the ring gear is in good shape with no teeth missing, or big chamfer ground on one side of it from starter not engaging properly.
Ric
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
