Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Header Question.
Old Feb 9, 2003 | 08:29 AM
MR. JORDAN's Avatar
Header Question.
I wan't to buy a set of headers and matching Y-Pipe. I don't want to spend a fortune on these, i just wand a set that works. Something like Headman's are fine with me. The problem is, I don't know what set to buy. The block I'm using is a 350ci that was in a early 80's Stingray.( Is now a Cammed 355ci) The headers are the last thing i have to buy before putting the engine in the T/A.
Can someone hook me up with some info? Or even better a part number...
Orrrr, If you have a set laying around that will fit. GREAT!
Thanks guys...
Jordan
Old Feb 10, 2003 | 05:08 PM
Ratchet's Avatar
Just order the ones that fit the stock 350 that was available in your car they will fit.
Ric
Old Feb 10, 2003 | 06:20 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
I got these ones - Hedman #68481 - for 5.7 TPI car. Came with y-pipe and are uncoated.
Installed OK but they are 1 & 5/8 which you may not want.
Had AIR tubes which had to removed because are f'kin ugly as well as useless.
I think Hedman has a similar set up w/out the AIR tubes.
Old Feb 10, 2003 | 06:25 PM
darbleinad's Avatar
Car: 84 Trans Am
the hedman shorties are a good unit. they have 1 5/8" primaries and 3" collectors. if want something cheap you could buy my flowtech headers. they are good, but have 1.5" primaries.
go to www.hedman.com
the 68480 's are the long tubes that i am buying to go with my pre-existing dual exhaust. i would definetly call canadian tire about ordering the hedman shorties. i called CT today and the hedman long tubes are $204.79. at the speed shop the same headers were $290. i will be ordering my hedmans from Canadian Tire later this week.
Old Feb 10, 2003 | 06:46 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
That aftermarket parts catalogue at Crap Tyre has good stuff and their prices were good on the things I got them to quote on.
Probably safer to have them import stuff for you and if they screw it up at least you can go after them here in Canada.
ZZ3Astro
Aug 13, 2019 12:57 AM
redformula88
Oct 14, 2015 06:08 PM
Chad Speier
Sep 24, 2015 12:32 PM
corey8084
Sep 17, 2015 02:56 PM
Ian Irvine
Sep 4, 2015 08:08 AM
