Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
window guide help!
Old May 16, 2003 | 05:28 PM
eddie jr's Avatar
window guide help!
So here's the deal:
Not sure if they are called window guides or not but I am referring to the little metal brackets with the felt on them that bolt to the top of the door (2 per side). They sit up against the glass and align it / stop vibrations. I guess the felt (or whatever material it is) is really worn because they are now nasty marks on the window top to bottom. I called the dealer here in Kitchener and they are $57 a piece!!! What the *** is up with that? Talkin' about dealer mark-up! And of course they said you can't just buy the material.
Has anyone had this problem before?? HELP!
Does anyone know of places where you can get these aftermarket?? I figure if I get them form the wreckers they will be just as worn.
Any help would be greatly appreciated!
Old May 16, 2003 | 05:45 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
$57 is pretty good actaully. I am pretty sure these are a dealer part, but I could be wrong, but for $57 buy them. But..the scrathces on your window arent' necessarily from these pices mentioned. Sometimes the actual guides inside the door get worn, and continuously scrape the window. Make sure you have the right part causing the problem before you start replacing parts.
Old May 17, 2003 | 08:07 AM
eddie jr's Avatar
what guides inside the window are you referring too?? Didn't know there were more. THe lines are lined up exactly with these pieces.
There is four of them though.......that's 230$ just for those little things. THe clutch kit cost less than that! Ahhhhhhhhhh!
Old May 17, 2003 | 09:16 AM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
If I remember correctly there is two metal guides inside the door. both have felt on them too, alot of time these are the true cause for these scrathces you speak of.
Old May 17, 2003 | 09:25 AM
eddie jr's Avatar
hmmmmm, thanks for the tip. I will have to check that out this afternoon when we continue assembling the interior.
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
kkirch15
Sep 30, 2015 04:44 PM
