Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
i can finally see my RPMs>this ok #s?
Old Aug 5, 2003 | 10:29 PM
icebird_1981's Avatar
ever since i got this car i could not see what the prms were as because my gauges are all messed up. anyway i went and got and aftermark rpm tech. so i am just double check to see if my idle is good. in gear its at 600 or 700,P or N, its at 1000rpms. is this ok?
Old Aug 5, 2003 | 10:45 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
1000 rpm in neutral is a bit high IMO - I don't know what the spec is but I'm usually looking for 600 - 700 in neutral on my carbed LG4.
Old Aug 6, 2003 | 12:13 PM
(BR)G-Machine's Avatar
If you configured it right for an eight then they work pretty decent. My friend with a six 6000 set his wrong, for a 4 cyl, but cept it cause he liked to think his auto was shifting a 9 grand.
Old Aug 7, 2003 | 09:50 PM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
Re: i can finally see my RPMs>this ok #s?
650-700 in P or D ( before acceleration ). Sounds like you need to make some adjustments to idle, unless that is you are certain your new rpm guage is accurate.
Rocket-Doc
Nov 14, 2015 02:08 PM
Antips16
Oct 30, 2015 06:42 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
