Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
can someone help me?
Old Sep 16, 2003 | 09:16 PM
icebird_1981's Avatar
k i made a post for this before in the tech but no one seems to no. i got a rebuilt wiper motor and it has a red and black wire hanging out>what do i do with them, what r they for?? i just thought all i need to do was plug in that one plug but there is these to wire hanging out
Old Sep 16, 2003 | 09:46 PM
Paul_Hughes_87 T/A's Avatar
Car: Chrysler 300c
Engine: 5.7L Hemi
Transmission: 5spd auto
Axle/Gears: 2.89
Is it a universal motor?
Does it work with the one wire plugged in?
Old Sep 18, 2003 | 12:05 AM
Eric2ndGen's Avatar
So you have the primary plug already connected? How does the motor operate like that?
Normally you have 3 or 4 wires on a wiper motor- power to motor, power to washer pump and grounds for 1 or both (both if you have intermittent wipers- but motor itself always grounds through assembly body). How many wire are on the plug you have already? Did someone put a remote fluid pump in the car, thus tearing apart the wiring on the harness that would normally go to the motor housing- thus explaining the "extra" connections on motor?
These wires that are 'hanging out'- is there a plug on them or are they hanging loose? Maybe someone was fiddling with a remote pump as the one in this motor gave out and their hack job left alot to be desired.
Where did this replacement motor come from? Compare the one you have with this one- if they are shaped differently you have the wrong unit- there are no "universal" replacements that I am aware of.
Buy a digital camera and take a picture and post it...
