Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Got my AFR's finally!!
Old Jan 22, 2004 | 11:51 AM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
12 weeks and they are here...And they look awsome!! All I need now are some RR's and the Super Ram runner's and plenum.
Old Jan 23, 2004 | 09:21 PM
Hawk92z-TDZ's Avatar
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
Old Jan 24, 2004 | 09:33 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Re: Got my AFR's finally!!
What did you get? I wish I hadn't sold mine but I had to. I got mine from ARE and it was pure hell.
Old Jan 24, 2004 | 09:56 PM
Car: 91Z
I got AFR 180's. I wanted the 190's, but they are now discontinued. The 180's took there place, and AFR said they bumped the 180 flow #'s up a bit . They will still rock with the 355 though!!
So to date my combo stands as:
Super ram
bbk 52mm TB
Accell base
Afr 180's, comp 987's, arp studs
LPE 219/219, 1.6RR(I think I will go with the comp pro mags)
Eagle forged rods and crank(going with procharger sometime)
Forged pistons ect, ect...
Acceld, the heads are 74cc and the comp should be around 9:1 with the new pistons, due to the possible NOS kit this summer, and the procharger in the next couple of years. I am going to switch to the LPE blower cam made for the Super ram and blower when I get the SC!! I bought them from Dix performance in Edmonton. I paid $2032..., that was with the heat riser. They had a set in stock without the heat riser and wanted only 1800 for them. Not too bad for canadian funds!!
Old Jan 26, 2004 | 12:26 AM
9:1 compression is perfect for boost
your new set up sounds sweet man, good luck
Old Jan 26, 2004 | 07:37 AM
Car: 91Z
Thanks Hawk, I just hope I can get it dialed in.
Rocket-Doc
Nov 14, 2015 02:08 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
ULTM8Z
Oct 2, 2015 01:25 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
