Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Changing to synthetic oil
Old Aug 24, 2004 | 09:02 AM
89tagta's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7
I am thinking about switching to synthetic oil on the next change.
Is it a simple matter of changing old and replacing with synthetic, or do I have to flush the old then add the synthetic. In otherwords, can a small amount of regular oil be mixed with synthetic?
I'm running a 350 TPI.
Thanks, Rob
Old Aug 24, 2004 | 10:53 AM
1gta2c's Avatar
Should be ok. I switched to synthetic with no problems at all and now I am using Royal Purple. I have had heard some people have a little oil leak because it is a thinner oil. I did have this problem with the tranny after I switched to a synthetic transmission fluid.
Old Aug 24, 2004 | 12:18 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you just change oil like you do with every other oil.
they are fully compatable.
the first time you change it though, change it a lil early, or around the same time as "regular" oil. synthetic cleans the motor out pretty good, and that means that the gunk the oil motor oil left will be cleaned off and mixed in with the synthetic.... just change it again after a lil bit and the motor will be happy and clean.
maroe624
Apr 16, 2017 08:29 AM
gixxer92
Sep 1, 2015 04:32 PM
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Zachattack0925
Aug 12, 2015 09:52 PM
