Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Cleaning paint off rims...
Old Jan 1, 2005 | 07:03 AM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
I'm wondering what i could use to clean 3 paint jobs worth of paint off the stock iroc rims. Theres the factory gold, under blue, under the now plum metallic. I've read something about aircraft paint remover from wal-mart, but will this really do the trick? could I have them sandblasted with something fine like walnut shells? Will the shells pit the wheels?
Old Jan 2, 2005 | 03:49 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
The paint stripper will work, but soda blasting is your best bet. Get's it all, without harming the rim itself. You can go over your windows with this stuff without harming them.
Old Jan 2, 2005 | 04:36 PM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Soda blasting, I've never heard of it. What is it?
Old Jan 2, 2005 | 06:11 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
It is basically just what it sounds like. Soda blasting through a sandblasting gun. It can be done wet or dry. Wet overall is a bit less messy. But it works great!!!
Sodsa has a non-abrasive action that allows it to be used on surfaces that the currently popular abrasive media (sand blasting) would damage i.e.: aluminum, stainless steel, brick, stone, glass, fiberglass, wood, plastic, seals, bearings, splines, radiator cores, and hydraulic cylinders. Since there is no heat build up warped metal is eliminated. The non-flammable properties allow soda to be used in the petroleum industry where other methods posed a higher risk. Sodium bicarbonate breaks down hydrocarbons, which makes soda blasting an excellent method of cleaning engines, engine parts, and other areas where oil and grease are present.
Old Jan 2, 2005 | 09:14 PM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Is this method popular? I have a feeling I'll walk into a place and ask them about it, and they may have me commited.
Sounds what I need though, no piting.
Old Jan 3, 2005 | 07:04 AM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
It is fairly popular around these parts, I am sure they will know what your taking about... if not try another place.
Street Lethal
Apr 30, 2019 12:14 PM
Hawk312
Aug 22, 2017 08:55 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Victor6
Aug 30, 2015 02:09 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
