Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Headlights
Old Jun 10, 2006 | 09:46 AM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
Headlights
Has anyone here with an older model Trans Am 82-85 swapped the headlight assembly for a newer style 86-92?
My friends 83 Trans Am's headlight motors dont work and I noticed there are no kits to fix those motors, Can I swap a headlight assembly from an 87 into his?
Will it just fit and work or are there some differences in size or plugs?
Old Jun 10, 2006 | 10:44 AM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
healdight motors werent redesigned until 87 , 82-86 have the same motors. I knmow there is relays to change , as well as changeing the headlight switch with a 87 and up car , or moving 1 wire on the old switch.
Old Jun 10, 2006 | 04:31 PM
transamice's Avatar
Car: 87 GTA t-top
A relay, ok but still is the whole light assembly the same bolt on, can I just swap one from an 87.
Just need to confirm before the guy goes spending money for nothing.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
