Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
rear disc conversion
Old Feb 17, 2009 | 07:39 PM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
I have an 87 GTA with rear drum, I got a rear axle with PBR disc brakes from an 89 GTA.
Can I use the 87's axle and change the mounting plate, calipers from the disc axle or do I have to change the whole axle?
Old Feb 19, 2009 | 06:02 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Re: rear disc conversion
Ed miller has a kit for it.
The rear end on your car now is a 10bolt, the 89 GTA is a 9bolt.
Old Feb 20, 2009 | 08:20 PM
transamice's Avatar
Car: 87 GTA t-top
What gears came with the 9 bolt rear ends?
Is there a number on the axle to verify?
Which is the better axle, stay with 10 bolt or just swap to 9 bolt?
Old Feb 20, 2009 | 09:03 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The nine-bolt is marginally stronger, but parts are, or at least have been, difficult to find. No parts problem with the 10-bolt and the 89-92 PBR's are a plus. Gearing and limited slip also might be a consideration in choice between the 9- and 10-bolt.
https://www.thirdgen.org/forums/faq-...now-about.html
JamesC
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
zayne0
Aug 24, 2015 07:22 PM
