TFBA members, i need help........
Car: 1990 Iroc Z Convertible
Engine: LB9
I'm not a member of this organization but I was hoping that a member could direct me to a good Mechanic that knows these 3rd gen TPI motors. Does TFBA have approved garages that they recomend to members? I'm not looking for a discount, just someone who knows what the hell they are doing when diagnosing these tempramental powerplants(and who won't rape me financially), Four mechanics have looked at my car and nobody is sure what might be wrong with it.I'm about to blow my cork, summer is half over and I've barely used my car.
1990 Iroc convertible,305 tpi,Black with black leather interior,lowered,Taylor 8mm wires,K&N's
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
If you're living in Bowmanville how far are you willing to go to get it fixed.
There's a shop in Toronto called Kane's Performance which is good. You might want to call them up. 416-466-0006
I was going faster than I'd ever gone before but then I fell off.
Two come to mind, they're performance shops, but I'm sure they may be able to help you out. Try High Tech Racing at (905)856-5858 (in Woodbridge) or Agostino Racing Engines (don't know the number). They are both reputable shops. If they are too far or too busy to help you, see if they can reccommend someone closer in your area.
1987 Camaro IROC-Z
350 TPI (L98), HyperTech Airfoil, K&N Filters and modified airboxes, AC Delco RapidFires, Taylor SpiroPro 8mm wires, Energy Suspension polyurethane bushings for front and rear LCAs and sway bars, KYB struts and shocks, BFG g-Force Z-rated tires, MAC STB, MAC SFCs, JET low temp stat, CarSound Hi-flow Cat, DynoMax 3" Mandrel-bent pipes, Flowmaster muffler, 3" chrome tailpipes, Corvette Servo, TransGo Shift Kit, Corvette 2000 Stall, TruCool LPD tranny cooler, T-tops, and White exterior with red leather interior.
2001 Sunfire GT
Bone stock 2.4L, 5-speed, K&N cone filter, interior detailing, 200W Monsoon Sound System (8 speakers), Silver Metallic exterior with grey interior.
3rd Place Stock Class at annual 2001 JCO Bash
Web: http://www.angelfire.com/on3/whitelightening
1987 Camaro IROC-Z
2001 Sunfire GT
Engine: LB9
Johnny Iroc, I have had this problem for 2 months now. I have replaced several sensors and have looked for vacuum leaks, I have posted my problem several times(usually after the latest sensor has not fixed the problem). I don't have alot of equipment(or knowledge of how to use it) to test all of the components that may or may not be causing this problem. I need someone who knows these powerplants and could point me in the right direction. I work in Toronto so going there to see a mechanic is not too much of a problem. Thanx
Pac J
May 17, 2020 10:44 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
LT1Formula
Oct 8, 2015 08:34 PM
