Yes the kid told me it was a temp fix and I neglected it until now... So my options are... try to fix this myself where my car sits on a side street... or just pay for a tow truck to bring it to shop. This is a little job it seems and if I do bring it to a shop, I'd like to be armed with adequate knowledge so they don't try to rip me off.
Thirdgen89GTA
close
Just pull the cover down, and use a zip tie to hold the rod on the pin if the rod is not broken).
The clutch rod never experiences any side loads.
thanks i'm going to get under there tonight if it's still light out at 6:30 tonight...
DD9TransAmGTA
close
I'm going to try to replace all my rod bearings this week. I really wanted to have my headers and borla catback installed for thirdgen fest but it looks like i'm showing up with the straight pipes lol. It sounds terrible
I am not trying to post on the wrong thread category but i got under the dash and the previous owner welded/bungee corded the clutch pedal to the MC pushrod.. because the hole on the rod is worn and so is the peg on the pedal...
Only thing i can think is it needs a new pedal assembly or master cylinder with parts that aren't worn... or cut off the peg and re-drill a hole on my current clutch pedal, then use a bolt and washers and nut to put through and secure to the pushrod.. damn it i don't have the tools to really pull that off right now..
DD9TransAmGTA
close
Ughhh 22 days till the fest and i found out my engine in the formula is junk. It not only spun a bearing but the crank is junk
Good thing running 305s or 350s are cheap.
^ha!... I am replacing my master cylinder as the ring on the pushrod has a washer half-welded onto it and the pushrod is wobbly from being jimmy rigged to the linkage this whole time. And a used pedal assembly from Hawks because the linkage is, well, gone... lol... missing the whole linkage part basically. Will have it all fixed up for TGF...
DD9TransAmGTA
close
Quote:
I tracked down a running 350 TBI to put in it, I'm going to replace the timing gears, chain, spark plugs, and check the cam.Originally Posted by xpndbl3
Good thing running 305s or 350s are cheap. Member
I am debating on going, I am finishing up the installation the engine and trans in my '88 Formy 350. I will have my license back on the 22nd (long story) and I was planning on going to the Lane Automotive show up in Watervaleit, MI but now I saw the stuff for this............
always a good time here, car running or not.....
Quote:
I am looking at it now, it's not a bad drive from FT. Wayne. I live in South Bend and i am thinking of going. Maybe we can roll together.Originally Posted by 1989formulakid
Im moving to fort wayne indiana next month so if money looks good by memorial day i'll be able to come to my first third gen fest. I believe it would be a 2 1/2 hour drive from where i am. Supreme Member
Pete you can roll with 92RS(real slow) and myself. If we get it done in time it would be fun to bring a certain 83 Z28 CFI 5spd car back to it's owner.....
after of nearly a yr without be started, last tgf charged up the battery and got it fired up but still not sure if i will go to tgf or not
Thirdgen89GTA
close
Well TransAm is not going. I just spent all day fixing my moms car instead of the GTA. Ugh. So the engine is still not in the gta. Not even assembled yet, nor is the bay painted. Tomorrow is mothers day so i cant work on it either. Since I want to do it right ill just be bring myself and my Focus ST.
Quote:
No!! You still have some time. Make it happen.Originally Posted by Thirdgen89GTA
Well TransAm is not going. I just spent all day fixing my moms car instead of the GTA. Ugh. So the engine is still not in the gta. Not even assembled yet, nor is the bay painted. Tomorrow is mothers day so i cant work on it either. Since I want to do it right ill just be bring myself and my Focus ST. Member
Good Deal 1MeanZ, looking forward to it. That Z28 will be nice to see driving!
Hi I'm we to the site and so far it seems to be a great site and a lot of free info I'm hopping to make it but my car won't be ready having a new motor built.
i wish i could make it this year, hell id bring mine stock, but im still having "issues" with my drivers license lol, hope to make it out next year though and by then the car will be nearly complete
going to missouri to pick her up next weekend be back in mn by the 20th so excited!!!!! 90k original miles im the third owner, been in my family since 1985, still has the "sheepskin" seat covers my aunt bought for it when she got the car, no rips or wear on the interior
