fuel pump needed for 355
Old Apr 15, 2002 | 03:09 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Most of you probably know about the motor I am have. 355, AFR , xtreme cam, 24lb injectors, Hooker long tubes, 10.5/1 compression, fully done TPI . The question is do I need a helper fuel pump to keep up with the extra hp, or what. The car was originally a 305TPI car. If so, what is everyone running.
Chris
Old Apr 15, 2002 | 03:34 PM
TBurke's Avatar
I have an 85' ex 305 similar to yours
355 AFR 190's
cam
I ran the stock pump on the engine and never had a lean problem.
I changed to a 190lph pump becuase I thought the pump went bad.
This works up over 400hp and is a direct replacement.
They also make 255 lph in tank pumps in case your really worried.
Also, I just put on a Paxton SN-2000 that I plan on running with the 190lph. I may add a booster if I need it.
Old Apr 15, 2002 | 10:04 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
I am gonna run nitrous on it also. Maybe I will just get a booster pump?
Old Apr 16, 2002 | 10:35 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Any suggestions for a good, almost bolt in booster fuel pump??
Chris
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
beachrodder
Aug 25, 2015 08:05 AM
Kaweh
Aug 9, 2015 02:54 PM
