LT1 heads on L98?
Old Apr 15, 2002 | 05:39 PM
johndo1707's Avatar
LT1 heads on L98?
hi, i have a set of lt1 heads and i was wondering if i bought the scoggin dickey tpi base if i could use the heads on an L98 block? thanks
Old Apr 15, 2002 | 06:00 PM
Adam62083's Avatar
I dont think so....I think its the reverso cooling.
Old Apr 15, 2002 | 06:09 PM
camaro6spd's Avatar
it is????do the water jackets line ne where close to each other? maybe you could get a gasket for a LT1 and put it on the block or an L98 gasket and put in on the Lt1 heads
Old Apr 15, 2002 | 06:17 PM
Adam62083's Avatar
Nah the block requires a lot of machining. Which means lots of $$$$. It wouldnt be worth the time. Get some L98 Vettes and port em or another good head designed for the block.
Old Apr 15, 2002 | 06:52 PM
RedIrocZ-28's Avatar
Car: Iroc-Z
Engine: 355 AFR'd HSR
Stock LT1 heads will not fit an L98 block. The LT1 heads are reverse flow cooling. The coolant passages do not line up. The HEADS need the machine work, not the block. Its a marginal gain for the $$$ you are gonna spend. You can get a set of AFR's and bolt them right on. Its a big headache. I am gonna have to create a link to this tech article I have on this subject.
Old Apr 15, 2002 | 08:50 PM
Adam62083's Avatar
Thanks for clearing that up.
Old Apr 15, 2002 | 09:34 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Here's the CC write up thanks to TAS.
http://www.lt1intake.com/LT1_retrofit.htm
lt500r55
Sep 1, 2021 01:30 PM
midge54
Dec 27, 2019 04:14 PM
CRFred
Feb 7, 2016 11:39 PM
midge54
Aug 29, 2015 09:51 PM
TheExaminer
Aug 19, 2015 10:07 PM
