Problem with L98 after it rains!!!!!
Old Apr 15, 2002 | 09:40 PM
Raptor Pilot's Avatar
After it rains, either that day or the next,my car (91 Formula L98) will stutter and not rev above 2100 RPM's while in drive, and the whole car will start to shake. I can put the pedal to the floor and it will only slightly accelerate at about a mile an hour every few seconds, until I let of and ease back into the throttle. Nowtomorrow, if all goes according to schedule with no rain, it should be fine. Ok, so, I am supposed to look for possible areas where water is getting in under the hood into theengine compartment first right? Then am I to try and see if the ignition components are getting wet in the process? Any other ideas or suggestions here? Thanks in advance.
Old Apr 15, 2002 | 10:05 PM
ThirdGenZ28 92's Avatar
Car: 1992 Z28
Engine: Stock L98 with bolt ons.
Transmission: Stock rebuilt tranny with 2k stall and cooler.
I had that exact same problem with a 71 Chevelle YEARS ago and every time it rained the car would stall or shake and sputter and in the end it turned out being a hairline crack in my distributor cap. I did a full tune up after I found out the cap was the culprit and didnt have any more problems until I sold it. I dont know if this is your problem or not but worth looking into...
Old Apr 16, 2002 | 09:59 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
I agree that it's most likely an ignition problem whether it's cap or wires with bad insulation. Check the ignition sytem carefully.
Old Apr 16, 2002 | 10:44 AM
Jim 86 IROC's Avatar
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
I agree, either cap or wires.
Consider a HyperTech coil/cap/rotor and a set of MSD 8.5mm SuperConductors.
Old Apr 16, 2002 | 05:49 PM
90Form350's Avatar
yes, my parents had the same problem on their 68 I-6 Nova. Ignition related.
lt500r55
Sep 1, 2021 01:30 PM
IROC315
Oct 27, 2015 09:57 AM
italiano67
Aug 31, 2015 06:04 PM
TheExaminer
Aug 19, 2015 10:07 PM
matthew911
Aug 12, 2015 09:38 AM
