Problems with ECM maybe...
Old Apr 21, 2002 | 07:05 PM
Justin Moore's Avatar
Car: 1986 Z28
Here is the problem. When I turn the key to the on position the fuel pump does not turn on. But when I connect terminal G on the connector under the dash to a 12V source the fuel pump does turn on.
When I short out terminals A+B on the connector under the dash and turn the key to the on position, absolutely nothing happens. The coolant fan does not turn on or the SES light does not flash.
During the winter months I checked all the wiring under the hood, because I noticed alot of stuff was not hooked up, or wired incorrectly. Also I replaced the fuel pump and the fuel pump relay.
Is any of this an indication of a bad ECM or is there something else I should be looking at. The car is an 87 Camaro 350 TPI.
Any help would be appreciated.
Justin
Old Apr 21, 2002 | 07:51 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Justin,
Can you retrieve any codes?
Old Apr 21, 2002 | 08:17 PM
Car: 1986 Z28
No, I cannot pull any codes. I am almost 100% positive the light is not burned out either.
Old Apr 21, 2002 | 09:21 PM
cherrybomb86's Avatar
replace the ecm man keep it simple
Eric2ndGen
Nov 5, 2015 01:51 PM
mddaniel
Sep 8, 2015 05:16 PM
inferno15
Aug 29, 2015 01:48 AM
355tpipickup
Aug 19, 2015 10:02 PM
djmarch
Aug 10, 2015 08:42 AM
