help controlling the idle speed?
Old May 1, 2002 | 01:24 PM
1bad350's Avatar
hey guys, i need some help adjusting the idle speed, i have a 1990 350, and right know its ideling at about 1200 rpm, it was at 1700 but i adjusted the idle speed screw today, and it resulted in 500 rpm in the right direction, however adjusting it any more dosent do anything, what else can i do to get my idle speed down to 400 rpm, " thats where it should be right?" i think with it ideling that high results in poor stoping distances and premature brake failure as well as lowered gas milleage, am i correct?
Old May 2, 2002 | 12:17 AM
SMKNGTA's Avatar
Car: 1989 GTA
Axle/Gears: 9bolt 3.27s
Take a look at this.
https://www.thirdgen.org/techbb2/sho...hreadid=104279
Old May 2, 2002 | 07:02 PM
Jza's Avatar
Jza
You're adjusting it in drive, right?
Old May 2, 2002 | 10:26 PM
1bad350's Avatar
what do you mean in drive?
Old May 2, 2002 | 11:40 PM
Jza's Avatar
Jza
If your car is an automatic, you should set the minimum air screw while the vehicle is in drive (D). If it's a manual, then you should set it to 750 (I think) while in neutral. Then set the TPS idle voltage. If the vehicle still won't hold a steady idle, make sure the IAC motor is functional and the passages and pintle clean. If your motor is modified (ei. cam, heads, etc) and setting the min. air and TPS aren't helping the idle (and everything else is good) then you know you're at the point where getting into PROM programming will help you. Everything else is just a band-aid.
eightsixseven
Dec 16, 2024 01:50 PM
ezobens
Aug 19, 2015 10:29 PM
jbd1969
Aug 17, 2015 07:06 PM
perZ
Aug 15, 2015 01:17 PM
